Configuration with Minecraft - Error Code Kicks Everyone
Everyone on the server gets kicked off from this error that randomly happens. The error is “Internal Exception: java.net.SocketException: Connection reset” It resets us back with losing items that should not have been lost. Everyone is getting mad and we cannot figure out why this would be happening. We have looked online at everything and nothing has worked. Everything is saying this is externally happening. This problem started once the minecraft update happened and the new Java was needed (Temurkin 25). What do we do?
  • Tried going back to the older Java, but it won’t work because at least 69 is needed.
  • Restarting Server to give it a slight break
  • Changed the max tick to -1 thinking it might be lag shutting down
