Configuration with Minecraft - Changes to server.properties not saved
When calling the /whitelist list command in-game the server recognizes all the players in the text file and the console also does not show any errors, but even after /whitelist reload the problem does not change. Whenever I restart the server the white-list setting in the server properties is reset to false.
Thank you for any help!
  • Set white-list=true in the server.properties file
  • Added all players with their UUIDs to the whitelist.txt
  • Restarted the server
The whitelist file is a JSON, not a TXT.
You need to use the setting in the panel to enable the whitelist.
