| Product | AMP ‘Proteus’ v2.8.0.8 (Mainline) |
| Virtualization | Podman |
| Application | Minecraft Bedrock |
| Module | GenericModule |
| Current State | Ready |
On my Minecraft Bedrock server I need to change the property “server-udp-ports” to “(Public IP):19134-19159:19134-19159” instead of just “19134-19153” or else nobody can connect to it from outside my network. When AMP runs though it will reset it back to the incorrect and unwanted value of just the port range and nothing else. I’m not sure if I’m missing something here or if it’s a current limitation of AMP itself but it’s a big issue for me.
- Navigate to the instance’s folder
- Change the server.properties to use my required value
- Run the server binary without AMP
