Configuration with Minecraft - Active users number does not refresh and keeps going up
Product AMP ‘Decadeus’ v2.4.7.0 (Mainline)
Virtualization HyperV
Currently I have no one on the server and AWP still shows 2 users. I connected to the server to test it via LAN and was able to connect, then I connected via url and even though I was the only one in the server the number shows 2.
I fully admit this may just be me being bad with configuration of the server. Also, is there a way to add a password to the server?
thanks,
  • create bedrock server
  • login to minecraft for windows and connect to server via lan or url
  • disconnect and reconnect to server. Minecraft will show 0 users on server but AMP will show users
Hey, I have the same problem. Also, using AMP Discord Bot, logins are reported just fine, but when someone disconnects, there is no notification of logout. And, like to OP, active users keep increasing with every login.
Known issue, the regex needs to be updated since they’ve changed the join/disconnect messages again
