Configuration with Minecraft - A few forge Versions are not available
Specificly forge Versions 47.4.6 - 47.4.10
  • Go to Configure Instance
  • Go to Configuration
  • Go to Minecraft
  • Go to Server and Startup
  • Go to the drop down menu for the forge Version you want and the specified Versions are not present
I moved my server off of Amp due to this issue around a month ago when Java 25 support was added in 47.4.9. I would like to keep using Amp, but I won’t go back to Java 17.
Find the ForgeVersionManifest.xml file in that instances datastore and delete it, then restart that instance.
