Configuration with Enshrouded - High load and poor performance with resources to spare
Application Enshrouded
The game is running very badly, with frequent messages about high load. The server is around 70% load during these times, and should have resources to spare. RAM usage is low, and far from being an issue.
I did read about someone having similar issues, where migriting to a proton based container fixed the issues.
As an aside not, the metrics, apart from memory usage are entierly innacurate. Active users are dead wrong, always showing 0 users, and CPU usage is often wrong by 10x the amount, 5% often means 50-60% usage.
  • Restarted the application
  • Rebooted the AMP server
  • Assigned more CPU and RAM resources to the AMP VM. This did not change anything.
I am experiencing the same. I experience lag with myself being the only one on the server that has 4 CPUs and 16Gb of ram. Add another person and it becomes entirely unplayable spouting about high server load. There never registers a user on the console nor anything more than .1 ram utilization and zero CPU.
CPU Model Intel(R) Xeon(R) CPU E5-2660 v3 @ 2.60GHz
System Type x86_64
Platform Ubuntu 22.04.2
Product AMP ‘Decadeus’ v2.4.4
(Same As above)
From what I understand, this is an issue that everyone is experiencing running this game in Wine on Linux. It isn’t an AMP specific problem. However we are experimenting with different versions of Wine to see if anything can be done. For the time being the only real option is to use AMPs docker mode to limit its impact on the rest of the system.
Although the CPU load is certainly an issue, even at around 70% load, which i get when there are players connected, the game gets unplayable.
I would be happy to test any other configurations/containers.
From what I’m reading as well, this is true. Does AMP have the ability to use PROTON instead of wine? That appears to be the method others are using to get around this.
The latest version of the config is using Proton already. Make sure to update the instance configuration and you’ll be using Proton.
This is what I get when I’m updating it.
Upgrading instance Enshrouded01
Using cached archive: /home/amp/.ampdata/instances/AMPCache-Mainline-2440.zip
wine8: Pulling from cubecoders/ampbase
Digest: sha256:116332665c11b7d123fe30cdbdf90db1f4d0e4122da63c346dcd21e831f6b27d
Status: Image is up to date for cubecoders/ampbase:wine8
docker.io/cubecoders/ampbase:wine8
I have 4 cores thrown at it with 16Gb of ram. it seems to not be using it all but the CPU load shows ~ 45-50% usage. The load avg on the box shown by top hovers between 3.5 and 4 with 2 people on it.
edit
I apparently can’t post anymore because I’m a new user -
I did a refresh configuration and it is now working. I had one other person on with me and it didn’t tank like it did before. I will update here when I have more people than that on.
You need to do right click - Refresh Configuration
I’m guessing you mean right-click update?
That did update to use proton it seems. Idle load is significantly lower, so is load with one user. Latency is also much lower.
Unfortunately I am unable to test with more players right now.
