| Product | AMP ‘Phobos’ v2.6.4.0 (Mainline) |
| Virtualization | Docker |
| Application | Barotrauma |
| Module | GenericModule |
| Current State | Stopped |
Lua for Barotrauma extension doesn’t autogenerate LuaCsSetupConfig.xml in root folder of the instance, which is vital for certain mods, as it may allow unsandboxed C# code to run (say Harmony patches).
The said option is defined in XML as “EnableCsScripting” with a boolean, by default set to false. C# scripting support can also be checked by executing “lua print(CSActive)” in ingame console, which returns a boolean depending on C# scripting being active.
This option might be dangerous to the user, but most mods are not malicious. Could be just a toggle with a warning.
I do not need assistance with the issue as I’ve copied my own LuaCsSetupConfig from my local installation - only reporting this because someone else might have an issue with it.
edit:
Apparently Dedicated Server just doesn’t generate the config at all - you have to either copy it from the client (which does generate the file), or use the C# dummy mod.
- Enable Lua for Barotrauma in config
- LuaCsSetupConfig.xml missing + no way to configure it in panel
- Execute in console “lua print(CSActive)” - server returns False, which means no C# scripting.
