| Product | AMP ‘Decadeus’ v2.4.7.0 (Mainline) |
| Virtualization | None |
| Application | ARK: Survival Evolved |
| Module | GenericModule |
| Running in Container | No |
| Current State | Ready |
There are a number of settings missing in the UI, particularly the Egg, dinosaur mating and growth multipliers, as well as the per level multipliers.
I have attempted to add these in manually to the configuration file, however when the server is started all my changes are reverted.
I have tried making just a single change to try to pin down the issue, however this also shows the same issue.
I have also tried running the dedicated server outside of AMP, using my amended configuration file. It works as expected, so it doesnt appear to be an issue with the configuration file.
Please can you advise? Thanks!
- Stop server
- Check UI for settings
- Manually amend configuration file
- Start server
- Configuration file is overwritten with UI configuration
