Configuration with ARK: Survival Evolved - Issues with ports not being sent out?
Application ARK: Survival Evolved
Ive had this issue persist throughout other operating systems, other games seem to work fine eg space engineers and valheim however there seems to be an issue with ARK SE in particular, this also does not work when DMZ is turned on in the router either
Edit:
noticed it seems to still be an issue with valheim using the UDP game port but not the SFTP port (tcp)
  • Created ark server
  • waited for server to start
  • added ports to router for portforwarding
  • checked with an open port checker to see if the ports were open or closed (they were closed)
  • launched another instance, in this case valheim
  • added ports from valheim to router
  • checked ports using port checking tool (ports were open)
