Configuration with ARK: Survival Ascended - Set custom passwords for Ark ASA Server
Application ARK: Survival Ascended
I just want to set a custom password. Is there anyway to bypass this highly questionable (and potentially hazardous requirement) to publish my control interface on the internet just to set an internal password?
  • Set custom password through gameusersettings.ini or through the command line
  • Observe AMP overrides the password
  • Try to set the password through the instance Security & Privacy menu
  • Get the error “Using this feature requires that you are accessing AMP over HTTPS or via localhost.”
  • Wonder why Cubecoders tries to force users to expose the admin interface to the internet just so they can set a custom password
  • Wonder why Cubecoders tries to force users to install X11 GUI on a headless server just so they can use a web browser locally to set a custom password inside a container
The last two points are not valid. You can have https without exposing to the internet. You can create a SSH tunnel that will allow you to browse to the server on localhost, without having a GUI on the server
Anyway, search “allow user-defined passwords” and turn that on. Then you can set a custom remote admin password
Thanks for your response, “allow user-defined passwords” being set does not prevent AMP from overriding the internal GameUserSettings.ini or saving a password. One of the two methods you describe must be used to allow that option to work.
The process documented here is incredibly convoluted when considering this is a hard requirement to… set a password that AMP doesn’t arbitrarily overwrite:
