Configuration with Application Deployment - Wont load forge library needed for BMC4
Product AMP ‘Callisto’ v2.5.0.12 (Mainline)
Virtualization QEMU_KVM
Whenever I try to start my server with BMC4 loaded and the settings configured to the correct Forge version, it gives me this error message: “Error: Could not find or load main class @libraries.net.minecraftforge.forge.1.20.1-47.2.17.unix_args.txt”. Any help would be appreciated.
  • I downloaded the mod, and it worked fine, but I couldn’t access the world through the BMC4 launcher.
  • Next, I found the Forge version was amiss, so i changed it.
  • I went to start the server again, but this time it couldn’t find the library for my forge version.
You’re using the wrong Java version. You need Java 17 for MC 1.20.1
How do I switch over to Java 17?
There’s a search bar in the upper right of the Minecraft instance
