Field
Value
Operating System
Windows - Windows Server 2025 on x86_64
Product
AMPService ‘Phobos’ v2.6.5.2 (Mainline)
Virtualization
None
Application
Application Deployment
Module
ADSModule
Running in Container
No
Current State
Indeterminate
When the instance starts, it runs at http://0.0.0.0:443 instead of using HTTPS. I do not see information in the guide other than setting the S/N of the installed certificate.
[Documentation (2)]
There are a number of methods that can be used to set up secure HTTP (HTTPS) within AMP depending on your use case.
Note that with AMP Enterprise, use of HTTPS is mandatory.
1. Reverse proxy via nginx (recommended, Linux only)
If you use the default getamp.sh setup script to install AMP, and you select the option to set up HTTPS when running that script, AMP installs and configures an nginx reverse proxy and Let’s Encrypt certificate handled by certbot to provide secure H…
Stop ADS Instance
Set the Webserver CertificateSerial
Run the rebind to 0.0.0.0 over port 443
Don’t try to configure AMP’s internal HTTPS. Use a reverse proxy like Caddy
I wanted to avoid doing that, but I just added it to haproxy.
system
Closed
6 April 2026 21:07
4
