| Product | AMP ‘Deimos’ v2.7.2.0 (Mainline) |
| Virtualization | ProxmoxVM |
| Module | ADSModule |
| Running in Container | No |
Im want to setup amp with one ADS as a controller and two ads as my Instance Hosts. Connecting to my instances works. I can click manage but im not able to add roles.
I tried this with https(proxy) and without (no proxy) to be sure that its not my nginx proxy.
But im still getting the following error ```vbnet
Exception in API call Core/GetRoleData
JsonSerializationException
[0] (JsonSerializationException) : Cannot deserialize the current JSON object (e.g. {“name”:“value”}) into type ‘System.Collections.Generic.IEnumerable`1[GSMyAdmin.Authentication.AuthRoleSummary]’ because the type requires a JSON array (e.g. [1,2,3]) to deserialize correctly.
To fix this error either change the JSON to a JSON array (e.g. [1,2,3]) or change the deserialized type so that it is a normal .NET type (e.g. not a primitive type like integer, not a collection type like an array or List) that can be deserialized from a JSON object. JsonObjectAttribute can also be added to the type to force it to deserialize from a JSON object.
Path ‘Title’, line 1, position 9.
Is there maybe a bug or just some config that i need to change?
* Klick Manage on Instance
* Go to Configuration -> Roles Management
* Roles are Empty not even Super Admin is here
* Try to Create a new Role
* No new Role is created
* Got to the Logs and see ```vbnet Exception in API call Core/GetRoleData JsonSerializationException [0] (JsonSerializationException) : Cannot deserialize the current JSON object (e.g. {"name":"value"}) into type 'System.Collections.Generic.IEnumerable`1[GSMyAdmin.Authentication.AuthRoleSummary]' because the type requires a JSON array (e.g. [1,2,3]) to deserialize correctly. To fix this error either change the JSON to a JSON array (e.g. [1,2,3]) or change the deserialized type so that it is a normal .NET type (e.g. not a primitive type like integer, not a collection type like an array or List<T>) that can be deserialized from a JSON object. JsonObjectAttribute can also be added to the type to force it to deserialize from a JSON object. Path 'Title', line 1, position 9. ```
Edit:
Ok nevermind. Looks like this was a cache and proxy error.
I guess my problem was that my nginx config was missing
proxy_set_header X-AMP-Scheme $scheme;
So if someone has this problem.
Just delete your browser cache and double check all the headers.
