Configuration with Application Deployment - Minecraft - Neoforge issue
Unable to select neoforge version, which is causing the server to go into a crash loop.
  • select minecraft specific settings
  • goto server and startup to select neforge
  • afterwards, choose specific version and attempt to select version, there are no options
Stop the instance, then use the main web UI’s file manager to delete the instance’s NeoForgeVersionManifest.xml, then start the instance again
