Configuration with Application Deployment - Manage Instances after enabling Reverse Proxy
Virtualization VMware
Hi,
using current AMP on a LAN server.
Configured HTTPS as per this: Setting up secure HTTP (HTTPS) with AMP
This is with a self-signed cert, as this is only a LAN server.
Able to login to ADS instance.
However, when trying to manage a game instance, the item in the WebUI is just flashing, and nothing happens.
Deployment Log only shows this:
Managed remote instance Counter-Strike201 at h ttp://10.13.37.3:8081/ ----- had to change URL as Discourse would not let me post this topic as it converts to link, and only 2 are allowed
Authentication token for derchris requested by ManageInstance on behalf of derchris
And Event Log this:
derchris Dec 26, 03:21 PM ADS LogLevels.Activity Authentication token for derchris requested by ManageInstance on behalf of derchris
derchris Dec 26, 03:21 PM Core LogLevels.Activity Managed remote instance Counter-Strike201 at http://10.13.37.3:8081/
derchris Dec 26, 03:21 PM Authentication AuthAuditEvents.LoginSuccess
derchris Dec 26, 03:21 PM Authentication AuthAuditEvents.LoginAttempt Login attempt from 10.13.37.51 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:133.0) Gecko/20100101 Firefox/133.0)
Still able to manage instances when using the normal HTTP link.
Thanks,
derchris
  • Configured nginx reverse proxy
  • Set Reverse Proxy in ADS
  • Tried to manage game instance after login via reverse proxy URL
Edit1:
Already enabled debug logging, but does not provide any more logs then what I already have
Try clearing your browser cache, or use an incognito tab.
Also check to see if there’s an error in the browser’s console
