| Operating System | Linux - Ubuntu 23.10 on x86_64 |
| Product | AMP ‘Decadeus’ v2.4.8.0 (Mainline) |
| Virtualization | QEMU_KVM |
| Module | ADSModule |
| Running in Container | No |
I have AMP installed on two different servers as I wanted one to operate as just a dashboard and I wanted the other to be the actual host for the game servers.
I have spun up a Project Zomboid server and a Minecraft Java Edition server several hours earlier, but when I try to select the ‘Manage’ option from the ADS controller, the instance just blinks for a while and then does nothing. If I select ‘Manage in a new tab,’ a new tab opens and I get an error saying the AMP backend does not appear to be working.
- Spin up a new instance on a second AMP server from the ADS Controller console.
- Select the manage option from the instance menu.
- Select ‘manage in a new tab’ option.
Edit
Happened into the Console screen and saw this. It seemed relevant, but I do not know what to make of it.
Returned exception from API call FileManagerPlugin/GetDirectoryListing
NullReferenceException
[0] (NullReferenceException) : Object reference not set to an instance of an object
22:38:12
at FileManagerPlugin.WebMethods.GetDirectoryListing (String Dir) at GSMyAdmin.WebServer.WebAttributes.InvokeMethod (String MethodName, Newtonsoft.Json.Linq.JObject Data, m.Http.IHttpRequest request, ModuleShared.IWebSession Session, ModuleShared.WebMethodsBase MethodsClass, String RawRequest) at GSMyAdmin.WebServer.APIService.InvokeAPI (m.Http.IHttpRequest request, ModuleShared.IWebSession Session, Newtonsoft.Json.Linq.JObject Data, String RequestModule, String RequestMethod, String RawRequest)
22:38:37
22:38:47
Managed remote instance ADS01 at http://192.168.0.204:8080/
Authentication token for user requested by ManageInstance on behalf of user
22:42:12
LIM - Failure to make API call to FTBSkiesExpert01: Connection refused
22:42:17
22:42:22
22:42:31
22:42:36
22:42:42
22:42:47
