Configuration with Application Deployment - Latency
Virtualization VMware
Currently, my Enshrouded server is located in the United States (IP: 72.60.143.68), which is causing very high latency (ping) and ‘High Load’ messages for my players in Brazil.
Since Enshrouded is a game that requires low latency for combat, I need the instance moved to the Brazilian server to ensure playability. Can you help me with this procedure?
  • Contracting and Installation
  • Latency Check
  • IP identification: I verified that the IP (72.60.143.68) is located in the United States, while I and my players are in Brazil.
Please understand that this is the forum for the AMP panel software and not Hostinger support, so you’ll need to use Hostinger’s site to request a transfer.
