Field | Value |
Product | AMP ‘Phobos’ v2.6.0.12 (Mainline) |
Virtualization | None |
Application | Application Deployment |
Module | ADSModule |
Running in Container | No |
Current State | Indeterminate |
System Configurations:
- Both machines are PCs running Linux Debian 12
- Both are on the internal network and have no firewalls between them
- Both machines can communicate back and forth unimpeded ruling out connection issue
- Main machine has HTTPS configured
Main machine is a hybrid controller and it shows the target instances when initially loading the web panel but hides half the local instances and will not show local and target separately.
I have reran the setup process multiple times on both machines and tried setting the target to connect to hybrid via HTTPS and local addresses to same result.
Have deleted cache, used different browsers, used different devices, clicked the button on the far right of AMP panel that is supposed to separate target and local instances to no change.
Hybrid can manage target instances when they are shown but the issue is they disappear when the instance refresh button is clicked and that half the local instances on the hybrid machine are hidden until then.
Please help.
- Changed standalone main machine to hybrid setup using rerun setup tool
- Configured second machine to be a target and attached it to the hybrid controller
- Hybrid controller panel only shows target instances upon initial loading panel and hides half the local instances
