Configuration with Application Deployment - Failed to pair with controller
I’m trying to pair a new target to this controller but when I do the screen spins for about 30 seconds before returning “Failed to pair with controller.” I am using the url used to access amp, and I have also tried the direct local ip over http. The direct ip is immediately rejected.
Both machines have firewall rules for port 8080, and both machines can see and ping each other.
I’ve tried http/https, specifying ports, none work.
  • Login to AMP
  • Select “Pair”
  • Add the code in the target along with the URL.
