Configuration with Application Deployment - Ark cluster configuration not working
Virtualization QEMU_KVM
I have tried several configuration options related to the clusters option, but so far I have not worked out a way to get it to work. So far I have got the other Server to pop up when I want to travel to it but all the time I cant connect to it properly, so I think there is a problem with the Cluster Directory Override but since its my first time setting up a server with AMP, I dont really know what I am doing.
  • changed the path of the custom cluster directory to the path which is stated in the guide of yours
  • looked the problem up and found a “solution” in the same forum, did exactly what the author said
  • tried my own way to get it to work with a mix of both ways i have tried so far
