Configuration and Permissions - Deploy a tunnel through a VPS hosted on Bloom Host
Issue affects: Platform / AMP itself
Operating System Debian GNU/Linux 13
Architecture x86_64
CPU AMD Ryzen 9 9950X3D 16-Core Processor
CPU Topology 1S/4C/2T
AMP Version 3.0.1 “Neptune” (292ff5e)
RAM 48177 MB
Virtualization VMware
NATS Status Connected
What were you trying to do?
What did you not like?
It setup a tunnel but the tunnel is just marked as continually setting up and I get a notification occassionally telling me the tunnel is offline the tunnel is online back and forward.
How could it be made better?
I am unsure
Steps to Reproduce
  1. Deploy amp on VPS
  2. Setup with Public entry node AMPBuse file
  3. Try to use Tunnel
EDIT: Added Context Below
Okay first let me explain what my goal is.
Reach my AMP3 game servers through a public facing VPS without exposing my actual IP as well as potentially resolving game servers via a hostname ie moddedminecraft1.example.com and moddedminecraft2.example.com and so on with the game servers we desire.
So here is how we are currently setup and its working though I imagine I’m going to give some people conniptions
We run our game servers hosted from a custom machine locally on my network we built for the community it itself runs unRaid and the VM the game servers sit on is hosted through that. The VM is on its own NIC and that NIC is shunted into my DMZ.
My router that I use for my home is part of Unifi’s suite. It is a Dream Machine Pro. In the DMZ I have just passed a huge port range to it so there is no need to port forward each server manually. The control panel itself is connected to currently through a Cloudflare tunnel to the VM and is reachable at amp3.example.com (I am obfuscating my actual hostname in this post with example) If the tunnel works well I plan on dropping port forward range and leaving it in the DMZ, though in theory it should now be able to work behind my firewall in my normal net
What I am currently experimenting with, and its not working, is I have a VPS running AMP3 configured as a Public Entry through the networking tabs “Add Public Entry Node”. The Installer has correctly punched the needed holes on the VPS through iptables and both me and my VPS provider has verified the ports are open.
It’s getting stuck on the very last step “Joined” and on the panel side it says setting up the tunnel I let it sit like this over night.
This was actually a known issue to do with the way it establishes the connection ‘backwards’ - Beta 2 has a fix for this.
