OS Name/Version: Ubuntu 22.04.2 LTS
System Type x86_64
oaded Plugins | FileManagerPlugin, EmailSenderPlugin, WebRequestPlugin, LocalFileBackupPlugin, CommonCorePlugin |
Application Name | AMP |
Application Version | 2.4.2.0 |
Release Stream | Release |
Build Date | 21/02/2023 11:49 |
Problem Description / Suggestion:
First of all. Thanks for a good app with a fairly simple install and setup.
I baught this to run a small Conan Exiles server. In it’s settings accesable via the WEB UI (instance → manage → configuration → server settings) however I can only configure the following:
- Server name
- Map
- Custom map
- Player limit
- Server psw
- Admin psw
- Region
- Anti cheat
If I edit custom settings directly in the file DefaultServerSettings.ini in the Conan Exiles Sandbox/Config, save and reload the file it does not apply in the game. If I change settings while admin inside the game, for instance daytime from 30 → 60 min, it does not apply.
To put my sugggestion simply and straight forward. Would it be possible for you to, in teh very near future add so that every setting could be changed in your web UI. For example. Thrall convertion rate, daytime and Server messega (motd)?
Thank you in advance.
