Colony Survival Firewall Rules not being set and ports not listening
OS Name/Version: Windows 11
Product Name/Version: AMP V2.6.1.2
Problem Description: I have started up a server for Colony survival. I have started it with minimal configuration and everything works fine, except it will not listen/open up port the Steam Port, regardless of what I do. I have manually input firewall rules to allow it for inbound and outbound traffic. I have forwarded the ports on my router. I have changed the port in the configuration and attempted to set rules for the new port. Nothing works; the Steam Port just will not open.
I have run the ampinstmgr dumpfirewall command but it only displays firewall rules for my one other instance which is for Seven Days to Die. No ports are mentioned for Colony Survival
C:\Windows\System32>ampinstmgr dumpfirewall
[Info/1] AMP Instance Manager v2.6.0.6 built 20/11/2024 20:54
[Info/1] Using Windows Advanced Firewall firewall.
[Info/1] UDP/26907 (AMP:SevenDaysToDie01:GenericModule.App.Ports.$ServerPort)
[Info/1] TCP/26907 (AMP:SevenDaysToDie01:GenericModule.App.Ports.$ServerPort)
[Info/1] TCP/26906 (AMP:SevenDaysToDie01:GenericModule.App.Ports.$AllocsModPort)
[Info/1] TCP/26905 (AMP:SevenDaysToDie01:GenericModule.App.Ports.$RemoteAdminPort)
[Info/1] TCP/26904 (AMP:SevenDaysToDie01:GenericModule.App.Ports.$ControlPanelPort)
[Info/1] UDP/26903 (AMP:SevenDaysToDie01:GenericModule.App.Ports.$ServerPort3)
[Info/1] UDP/26902 (AMP:SevenDaysToDie01:GenericModule.App.Ports.$ServerPort2)
[Info/1] UDP/26901 (AMP:SevenDaysToDie01:GenericModule.App.Ports.$ServerPort1)
[Info/1] TCP/2224 (AMP:SevenDaysToDie01:FileManagerPlugin.SFTP.SFTPPortNumber)
[Info/1] TCP/8080 (AMP:ADS01:Core.Webserver.Port)
[Info/1] UDP/12820 (AMP:ADS01:ADSModule.Network.MetricsServerPort)
[Info/1] TCP/2223 (AMP:ADS01:FileManagerPlugin.SFTP.SFTPPortNumber)
And when I run the ampinstmgr updatefirewall command I only get the following:
C:\Windows\System32>ampinstmgr updatefirewall
[Info/1] No new firewall rules to add
[Info/1] No existing firewall rules to remove
[Info/1] Firewall is already up-to-date, no changes necessary.
It does not even detect that there should be rules for Colony Survival.
  • Step 1: start a Colony survival instance
  • Step 2: Set game configuration up and restart it
  • Step 3: try to connect to it
Tried to manually set up firewall rules and router port forwarding for the ports that Colony survival runs on, that didnt work.
Tried to run Amp commands to update firewall settings, that didnt work.
UPDATE:
Hi guys, I managed to fix it. When I started the Instance the actual AMP Software needed updating. So the instance and AMP versions were different. I updated AMP and deleted the instance and created a new one. I still had to run ampinstmgr updatefirewall to apply the correct rules but now it works fine
