OS Name/Version: Ubuntu 20.04.3
Product Name/Version: AMP Instance Manager v2.3.1 built 13/01/2022 21:17
Problem Description: Had to change AMP ADS URL for re-config on router and port forwarding.
Was successful in changing ADS URL to 192.168.1.100
Instance Satisfactory01 is still using old binding 192.168.1.21
Attempted to use:
ampinstmgr --ReconfigureInstance Statisfactory01 192.168.1.100 8081
However on start of ADS the Satisfactory instance is still tied to URL 192.168.1.21 in:
ampinstmgr --ShowInstancesList
Is there a different command or place in the ADS manager that I can change this?
A new instance does bind to the New URL but I’d rather not rebuild SteamCMD again
as that took multiple days to figure out all the terminal commands to create/move files
so that the Satisfactory Instance would work properly.
(I do intend to create another forum post about that later so others don’t have to go
through the same pains)
Any help would be appreciated.
– Update –
Gotchya,
Is it possible to rebind an instance to a static IP?
I’ve been able to resolve the Instance management issue for now - my router is seperate from this app so I’ll keep on that.
For reference:
Router lost connection to device - could still see MAC Address
- Restarted Network switch
-Still couldn’t see so opened to DHCP
-Router saw device, however after setting back to old Static address Router was stuck on DHCP address - Rebound AMP to new address
- Instance would fail to start
ampinstmgr --ShowInstancesList would return instance listening on old IP Address - instance would also fail to launch management GUI saying it was not Active
Attempting to get my router to find system on old address but if I cannot would be helpful to rebind instance to new IP
If not possible no worries! I’ll start from scratch on the new IP.
Recreating the instance will be easier than troubleshooting my router software.
Thanks!
