Product Name/Version: AMP Release “Triton” v2.3.2.10, built 21/04/2022 15:09
My server has 64g memory and no matter what I change the Container Memory setting to for an instance, it always shows that the full memory is available to the instance and can go above what I have set.
It doesn’t matter how many instances I have either. I set my main game server instance to 48g and it shows 64g when managing the instance. I set my second “dev” instance to 8g, shows 64g and goes over 8g when rust is started.
The AMP instance inside the container doesn’t know what the containers memory limit is, so it just reports the amount that the system has installed. This will probably change at some point but it’s really just a display issue.
I have 6 GB in the Ubuntu VM. I am using PaperMC. I allocated 4 GB to Java. I set the advanced Java option for starting RAM to 2 GB and max RAM to 4 GB. This is using the Docker option.
The Physical RAM usage makes sense. But why does Memory Usage show 8933 MB? And was the Docker memory reporting fixed from this thread? Because I don’t see 6 GB reference anywhere here even though the VM guest has 6 GB.
