OS Name/Version: Ubuntu 22.04
AMP 2.4.4
I currently have HAProxy set up for SSL termination and for path-based routing. Now, I would like to incorporate the AMP platform in a similar manner. Currently, I have AMP working as the default backend.
I attempted to set the base URL to “mydomain/amp” and used Rewrite Requests to remove the “amp” part from the URL. This approach allows me to access the main page successfully, but it doesn’t consider the base URL to load all derived links. Is there a recommended approach to achieve this properly?
Thank you.
