I initially installed Amp on a windows server machine as a stand-alone but it would be far more beneficial to use as a target managed by a different machine. I’ve spent the last 2 hours trying to reinstall and/or destroy the initial installs data so I can again get the options screen during installation. All to no avail. What am I missing here?
You might have broken it by now… All you had to do is go to Configuration->New Instance Defaults and there’s a Re-run Setup button.
Lol… ya. That would have been a lot easier. But then I had a problem with “pass-through authenticate” and said f*ck it. All 8 machines can run as stand-alone.
Thanks for the reply though
