OS Name/Version: CentOS Stream 9
Product Name/Version: bash <(wget -qO- getamp.sh)
Problem Description: Error loading shared library: /tmp/mono-bundle-vdequK/libsqlite3 /tmp/mono-bundle-vdequK/libsqlite3: cannot open shared object file: Operation not permitted
Sudo su -l
N
Y
N
Y
default user
password
password confirmation
enter domain
default email
Continue with Install
AMP System user: Already exists
Instance Manager: Already installed
HTTPS setup: Yes, via nginx with domain *******.****.***
Install Docker: No
Install 32-bit libraries: No
Install Java: Yes
Ready to install AMP. Press ENTER to continue or CTRL+C to cancel.
Installing AMP...
amp already exists. Skipping...
Updating System...
Installing prerequisites...
Adding Adoptium RPM repository...
Java could not be installed automatically for your distribution. Please install it manually after setup completes.
Updating System...
Press any key to continue.Installing Java for Minecraft...
Installing nginx and certbot...
Updating SELinux rules (httpd relay)...
AMP instance manager already installed. Skipping...
Adding firewall rules...
Adding firewall rule for port 443 (AMP Reverse Proxy) via firewalld...
Warning: ALREADY_ENABLED: 443:tcp
success
success
Adding firewall rule for port 80 (AMP Reverse Proxy) via firewalld...
Warning: ALREADY_ENABLED: 80:tcp
success
success
[Info/1] AMP Instance Manager v2.5.1.4 built 01/08/2024 21:38
Saving debug log to /var/log/letsencrypt/letsencrypt.log
Certificate not yet due for renewal
Deploying certificate
Successfully deployed certificate for ********.****.***to /etc/nginx/conf.d/********.****.***.conf
Congratulations! You have successfully enabled HTTPS on https://********.****.***
If you like Certbot, please consider supporting our work by:
* Donating to ISRG / Let's Encrypt: https://letsencrypt.org/donate
* Donating to EFF: https://eff.org/donate-le
[Info/1] Done!
Creating default instance...
Error loading shared library: /tmp/mono-bundle-3hRF9N/libsqlite3 /tmp/mono-bundle-3hRF9N/libsqlite3: cannot open shared object file: Operation not permitted
Failed to create default instance.
Removing generated nginx config...
Aborting...
Something went wrong during the installation. Would you like to upload your setup log for easy sharing?
This will upload /root/getamp-20240809-212836.log to the hastebin service and give you a URL you can share.
The log file may contain sensitive information such as username, any supplied domain names or your systems hostname so if in doubt - check
the file manually and upload it yourself.
[y/N] ```
