Carrier Command 2 has the following requirements:
- Xvfb and Wine are required on Linux. For this reason using AMP’s Docker feature is recommended
- The server uses four sequential UDP ports - 25565-25568 by default. Currently AMP cannot automatically ensure assigned instance ports are sequential, so this should be checked and adjusted as needed (right click on the instance, Edit Ports)
- On Linux, there is currently an issue with Xvfb/Wine that when the server is stopped, legacy processes may be left. This may affect subsequent server starts. In that case, a restart of the instance is required
(Credit to @Greelan)
