OS Name/Version: Centos8 Stream
Product Name/Version: AMP 2.3.4.3 - Mainline
Problem Description: Game server crashes before fully starting, actually similar to this thread [Can’t start V-Rising instance] except I’m running CentOS and not on a VPS
C:\windows\system32\mpr.dll:mpr.dll (00007F4B32DF0000), size: 151552 (result: 0), SymType: '-deferred-', PDB: 'C:\windows\system32\mpr.dll', fileVersion: 5.0.2195.6611
========== OUTPUTTING STACK TRACE ==================
RtlLookupFunctionEntry returned NULL function. Aborting stack walk.
- Login to AMP and create
V-Rising
server as a container - Manage
V-Rising
instance and click on console tab. - Click
update
button in console tab then clickstart
once update is done.
- Uninstalled manual docker installation and installed using
bash <(wget -qO- getamp.sh) installDocker
and verified workingDocker version 20.10.17, build 100c701
- Had previously installed wine manually to get server working (before moving to docker instances), removed it just in case
- Verified docker isn’t the issue by creating a containerized
Satisfactory
game server and worked just fine (no errors in console and able to connect to it)
In an effort to save time, providing output of commands asked for in the similar thread listed at the beginning of post
[root@smoothsailing ~]# docker --version
[root@smoothsailing ~]# su -l amp
[amp@smoothsailing ~]$ docker pull cubecoders/ampbase:wine
wine: Pulling from cubecoders/ampbase
Digest: sha256:e8c3180bbfba2762b91fec0effcd97fdf91aec459267bc31968894fc9353c117
Status: Image is up to date for cubecoders/ampbase:wine
docker.io/cubecoders/ampbase:wine
[amp@smoothsailing ~]$ ampinstmgr restart vrising01
[Info] AMP Instance Manager v2.3.4.2 built 11/07/2022 20:17
[Info] Stopping Instance: 'VRising01'
[Info] Stopping instance VRising01...
AMP_VRising01
[Info] Instance VRising01 has stopped.
[Info] Starting Instance: 'VRising01'
[Info] 1421d915467a157693c0a516154d5ca90a19ac13f690b00d6225352d65f8674c
[amp@smoothsailing ~]$ ampinstmgr validate vrising01
[Info] 0 missing files, 0 damaged files.
[Info] All files passed OK!
UPDATE: While trying to answer Can you make a new instance for me and check that two instances fail in the exact same way?
The previously failing seems to work now once I started the second server but the second server is failing the same way the first server did. It’s as if the second one is being sacrificed in order for the first to work
