Product Name/Version: AMP Release “Triton” v2.3.4.4, built 26/07/2022 20:08
Problem Description: I have created a first Instance of Minecraft Bedrock on Port 19132/19133 and can start that Server without any problem. Then I created another Minecraft Bedrock on Port 19134/19135 but that one won’t start, the Server is never finishing the Start sequence. What I could see is that, even if I adjusted the Port used for the server on the instance, the Port for IPv4 in minecraft.conf still was 19132 while the IPv6 had another number.
21:15:47
[21:15:47] NO LOG FILE! - [2022-08-10 21:15:46:663 INFO] Starting Server
[21:15:47] NO LOG FILE! - [2022-08-10 21:15:46:663 INFO] Version 1.19.11.01
[21:15:47] NO LOG FILE! - [2022-08-10 21:15:46:663 INFO] Session ID 14278d82-b82b-4537-8208-7d1dfbe5a488
[21:15:47] NO LOG FILE! - [2022-08-10 21:15:46:664 INFO] Level Name: Name
[21:15:47] NO LOG FILE! - [2022-08-10 21:15:46:674 INFO] Game mode: 1 Creative
[21:15:47] NO LOG FILE! - [2022-08-10 21:15:46:674 INFO] Difficulty: 2 NORMAL
21:15:49
[21:15:49] NO LOG FILE! - [2022-08-10 21:15:49:051 INFO] opening worlds/Name/db
21:15:50
[21:15:50] NO LOG FILE! - [2022-08-10 21:15:50:758 INFO] IPv4 supported, port: 19134
[21:15:50] NO LOG FILE! - [2022-08-10 21:15:50:758 INFO] IPv6 supported, port: 19135
21:15:51
[21:15:51] NO LOG FILE! - [2022-08-10 21:15:51:118 INFO] Server started.
[21:15:51] NO LOG FILE! - [2022-08-10 21:15:51:181 INFO] ================ TELEMETRY MESSAGE ===================
[21:15:51] NO LOG FILE! - [2022-08-10 21:15:51:182 INFO] Server Telemetry is currently not enabled.
[21:15:51] NO LOG FILE! - [2022-08-10 21:15:51:182 INFO] Enabling this telemetry helps us improve the game.
[21:15:51] NO LOG FILE! - [2022-08-10 21:15:51:182 INFO] To enable this feature, add the line 'emit-server-telemetry=true'
[21:15:51] NO LOG FILE! - [2022-08-10 21:15:51:182 INFO] to the server.properties file in the handheld/src-server directory
[21:15:51] NO LOG FILE! - [2022-08-10 21:15:51:182 INFO] ======================================================
[21:15:51] NO LOG FILE! - [2022-08-10 21:15:51:398 INFO] IPv4 supported, port: 50297
[21:15:51] NO LOG FILE! - [2022-08-10 21:15:51:398 INFO] IPv6 supported, port: 50298
- I have tried to remove the Instance and do new one.
- I have tried to move the Port to 19136 or 19138.
- I have tried to start the Second server first and it worked fine but when I start the first server I got Error that Port is already used.
