Can't mange instance, white flashing border
Operating System Ubuntu Linux 26.04 Bare-metal
Product AMP ‘Proteus’ v2.8. (Mainline)
Problem:
Every time I set up a new server and I click on manage I just get a white flesh and border and no matter what I do nothing works, I’ve been added for hours now and nothing I have tried works including a fresh reinstallation of both the Linux server operating system and amp.
Create new instance, select any game on the application list and then create the Instance, wait for the instance to be done creating and then click on manage instance, I click on manage instance and immediately following is a white flashing border.
Actions taken so far:
I have cleared my browser cache.
I have a reinstalled the server and amp from scratch twice.
They have tried to update the server through ssh, this has also been done several times,
Have also tried to resolve the mismatch release streams with the following command:
ampinstmgr stopall
ampinstmgr reconfigure ADS01
ampinstmgr upgradeall
ampinstmgr startall
Which has also not worked, the most frustrating thing is everything worked perfectly fine before I updated to the latest version, I have checked other forums and I have checked posts from the past and gone through Steps from those as well which also hasn’t worked which involved updating and trying to fix mismatched versions.
I feel like I am losing my mind and I have tried everything, please help…
Edit, checked the Deployment log, no matter the game I set up it’s the same error:
LIM - Failure to make API call to AbioticFactor01: Connection refused (127.0.0.1:8082)
LIM - Failure to make API call to Avorion01: Connection refused (127.0.0.1:8081)
Edit 2, I’ve now also tried to run AMP via in Proxmox with Debian 13, have the same problem as i have on a bare-metal machine, white flashing box with the same failure
