OS Name/Version: windows 11 pro
Product Name/Version: 10.0.22631
cant connect and says Failed to login: invalid session when connecting.
edit the server.properties and set online to false
selecting server.properties and pressing Import configuration
start the server
check server.properties just to see online config goes back to true (crying)
edit the the online line to false and pressing import configuration but still cant connect and says Failed to login: invalid session when connecting.
I used my brothers pc because he has bought mc and it works well. And one thing i noticed was when he is joining at the server the loading sequence was (joining world> logging in > encrypting) so im pretty sure the reason i couldnt join is because the server is still set to ONLINE
