Cannot login to management? panel
OS Name/Version: windows 11
amp instance manager 2.3.1.2
Problem Description: unable to login through management panel
provides syntax highlighting.
  • Step 1 download amp
  • Step 2 run instillation wizard
  • Step 3 automatically open management panel
Actions taken to resolve so far: several re-installs
instillation onto a different pc
attempt at password reset
You need to be more specific. Are you able to actually reach the panel, but it refuses your login?
I can reach the login itself, but it refuses it.
I am having the very same issue on windows 10 pro
Reset the password on the command line using ampinstmgr resetlogin and make sure to use a plain password, letters and numbers only.
what value are we meant to put for the instance name?
If it asks you, generally it’s “ADS01”.
I have had the same issue. I have reset my username and password to the same and different things multiple times and I am still unable to login. I went through the steps in the following links to change my login information.
I have no idea what this linked me to. I have a hosting service with Hostinger. I can’t log into the server page to restart the server. I just clicked to reset my PW. I don’t have AMP. (edit: I went through their main site and got past this login. I’ll just leave them a note that it brings people here)
Hostinger use AMP as the management platform for the game servers you rent from them.
