OS Name/Version: Ubuntu Server 20.04 LTS / running as a VM within Proxmox
Product Name/Version: (Always use the full version number - not ‘Latest’): AMP Instance Manager v2.3.4.4
Migrating the VM from ESXi to Proxmox changed the MAC address and maybe other settings. So AMP is wanting me to reactivate the instances.
I copied the licence key using the GUI under Configuration / New Instance Defaults, no effect.
When trying to run
ampinstmgr reactivateall
I receive an error message (“not a valid licence key”) -
I requested the key again from https://manage.cubecoders.com/ to make sure it is correct, no effect (licence key in code snippet below replaced with dummy data):
[Info] AMP Instance Manager v2.3.4.4 built 26/07/2022 20:09
Please enter value for Licence Key
>12345678-1234-1234-1234-1234567890AB
[Error] 12345678-1234-1234-1234-1234567890AB is not a valid licence key.
