OS Name/Version: Ubuntu 20.04.5 LTS 5.4.0-126-generic
Product Name/Version: AMP 2.4.0.6
I created Fabric Server Instance (Server Settings: Fab M V: 1.19.2, Loader: 0.14.9, Installer: 0.11.1)
Started Server
SFTP’ed into server minecraft directory (root). All is well.
copied my modpacks mods/default config/config folders over.
removed world directory and restared server
Connected with client and ran for server for about a half hour. All is well (great performance).
Next day. stopped server to add mods.
SFTP’ed into server root (minecraft directory)…
This is the error in WinSCP:
General failure (server should provide error description).
Error code: 4
Error message from server: I/O errorCommon reasons for the Error code 4 are:
- Renaming a file to a name of already existing file.
- Creating a directory that already exists.
- Moving a remote file to a different filesystem (HDD).
- Uploading a file to a full filesystem (HDD).
- Exceeding a user disk quota.
I can copy/delete/edit/add files though the built in manager to the root minecraft directory.
Here is the strange part, I can go an any subdirectory via login, like:
/mods
and I get in just fine though SFTP… it’s on the root directory that throws that error and only after it’s restarted.
- Removed Instance
- Setup New Fabric Instance
- Configured Memory and server/started and allowed to finished setup and idle, then stopped
- Connected using the “Connect to ftp link” on root minecraft directory… no problems
- copied up mods, config and default config directories… nothing else…
*stopped instance
*started Instance
*managed server and started minecraft fabric server - connected with client, broke a few blocks, closed world, shutdown server from console
- Chose file manager from console (root directory) and used link…
- Same error as above.
*choose file manger and went to mod folder and had no issues, chose config folder, no issues… but I have root is a no go. - Since I’m admin I logged into the root of the AMP server (not in an instance)… navigated to the server/minecraft directory and got the same error… all other directories are accessible
- Installed another instance of fabric server. can access Minecraft directory. Added mods and configs only. Started minecraft server. Can’t access minecraft directory via sftp. All other directories respond (url with /directory works).
