Application Control Manger
After a lot of searching for the best server management panel, I stumbled across this amazing software by Cubecoders.
Operating our own server network is really hard and has its own set of problems.
also, team management and access control are annoying &
cost a lot of development time.
AMP, makes it easy to manage, create, edit, and maintain game servers.
Our Exspirance
We are using AMP for the last 3 months and it’s been a life-changer!
AMP doesn’t have any hidden fees & or limits on a lot of things that should be free from the beginning, most other competing management panels have a lot of hidden fees.
Also, the installation just works… no need to overcomplicate things with a lot of preparation… just like installing any other software on the PC. This is a huge game-changer
Because some panels have so many other things that you need to set up before you can access your panel (MySQL database, NPM packages, some add-ons…)
2FA & security, Well if you know something about passwords is that they can be craked or leaked somewhere and its dangerous esspshily if that developer has access to critical function or data.
AMP, has so many security features witch meant to protect your dashboard & team from most of the known attackers (ex: Brute Force Attack) by incorporating nice fetures like 2FA, DDOS protection, limitations, IP whitelisting, and much more!
Instance deployment and management, the soul fact that you have over 20+ supported games is just mind-blowing
managing the Instances is so simple even a non-dev person can understand what’s going on, all the things you need are just laid out for you.
Just fill out the fields and you are done.
Our Game Servers
We are using AMP to mannge our intres comunity game network, here are some stats
Our Servers
7 Minecraft Servers
4 FiveM Servers
2 Up Comming Rust Servers
and 5 Planned servers for CSGO
And More Are Comming soon in the Q4 of 2022
Our Team
We have a team of 15 amazing devs that are working around the clock on the servers and are using the pannel everywhere… and so far no problems. It simply just works.
Discord Bot Integration
This is one of the amazing features that AMP has and it helps us to see & control quickly our servers
Best Things about AMP
The Best thing is the auto-restart and the sleep mode, the sleep mode cuts our power bill by 34% percent which is important and is good for the environment.
The auto-restart is a lifesaver because sometimes a server might fail or crash when under load or something is happening AMP quickly restarts the server and all the players can get back in like nothing has ever happened.
BackUp, is also amazing and works with no problems.
Personal Note
Thanks, Cubecodes for making an amazing piece of software, and for the fast support & help
thefourCraft, COO on @IMS_Network
Twitter: @network_ims
Discord: https://discord.ims-network.net
