OS Name/Version: RHEL 9.0
Product Name/Version: AMP One-line installer.
There’s a bug with the installer and the creation of the adoptium repo for yum. It’s adding a 9.0 to the repo URL when the actual URl contains just a 9 for the RHEL repo.
Updating Subscription Management repositories.
Adoptium 35 B/s | 80 B 00:02
Errors during downloading metadata for repository 'Adoptium':
- Status code: 404 for https://packages.adoptium.net/artifactory/rpm/rhel/9.0/x86_64/repodata/repomd.xml (IP: 54.148.95.12)
Error: Failed to download metadata for repo 'Adoptium': Cannot download repomd.xml: Cannot download repodata/repomd.xml: All mirrors were tried
Bad adoptium repo config.
[Adoptium]
name=Adoptium
baseurl=https://packages.adoptium.net/artifactory/rpm/rhel/9.0/x86_64
enabled=1
gpgcheck=1
gpgkey=https://packages.adoptium.net/artifactory/api/gpg/key/public
Good adoptium repo config.
name=Adoptium
baseurl=https://packages.adoptium.net/artifactory/rpm/rhel/9/x86_64
enabled=1
gpgcheck=1
- Step 1 Create virtual machine using rhel-baseos-9.0-x86_64-boot.iso.
- Step 2 Logon and run one-liner script.
If I modify the /etc/os-release/ file and remove all the .0’s from it, it creates the repo with the correct url and installs fine.
