OS Name/Version: Debian GNU/Linux 13 (trixie)
Product Name/Version: AMP Instance Manager v2.8.0.4 built 24/07/2026 17:14
Aloha everyone,
first at all: my english wrting skills are horrible but there is a that I can’t resolve on my own.
I tried to bind the AMP Webserver to a wireguard ip address so the WebInterface is only accessible via the WireGuard VPN.
The following commands are used as suggested in other threads:
ampinstmgr stop ADS01
ampinstmgr rebindinstance ADS01 192.168.200.1 8080
ampinstmgr repairauth standalone http://localhost:8080
While doing these steps I used watch and grep to get Webserver.IPBinding.
Doing the rebind changes the ip to the desired one, but repairauth changes it back to 0.0.0.0.
Is there a way to change ist permanently to the desired ip or would you suggest to block the port for incoming connections on the public ip?
- Stop instance
- Rebind it to other ip with same Port
- Repair auth
- Changed the URL in repairauth to URL with the desired ip e. g.: http:// 192.168.200.1:8080
