Best practice for Backup → Update → Start workflow?
Hi everyone,
I’m trying to build a simple maintenance workflow with the AMP Scheduler and I’m wondering if I’m missing something.
My goal is:
Take a Backup
Update Application
Update all Store Entries
Start Application
The important part is that I only want the server to start after both update processes have completely finished.
However, what I’m seeing is:
  • Application - Update the application starts the update and the scheduler immediately continues.
  • Store - Update all store entries also starts and the scheduler immediately continues.
  • Application - Start the application is executed while the update(s) are still running in the background.
From what I can tell, the update tasks seem to be asynchronous.
Is there currently any way to wait until these tasks are actually finished?
For example:
  • a scheduler condition
  • a task status variable
  • a “wait until update complete” action
  • or any other recommended approach?
Using a fixed delay (Wait) would work as a workaround, but I’d rather avoid guessing how long updates might take.
I’m running AMP 2.8.0.4.
How are you handling this in your maintenance schedules?
Thanks!
