Backup Restore Issues
OS Name/Version: Windows Server 2019
Product Name/Version: AMP Release “Callisto” v2.5.1.6, built 16/08/2024 03:11
Having some issues with Restoring a server, I had to reinstall AMP on another computer, and beforehand I used the backup to grab a backup of the system before i decommissioned and reformatted the old system. (Game specifically is Vrising)
Anyways, im trying to reinstall the backup i did (which had specific configuration files and some player data), and I have ran into several obstacles.
I dug through the forums and found several posts, One indicated to just unzip the folder into the other one (I found the matching directory and unzipped it), which then suddenly made the instance unbootable and crashed when it started, Removed the instance, reinstalled it. Another post recommended restoring the backup, copied the file to the Backups folder in AMP, and restarted the instance and the system didn’t show up, (I also copied the JSON file in the backup folder thinking that this might make it show up (no luck).
One one of the Manual copies i finally got the system to Boot after i copied the files over, but everytime the system booted up it didnt recognize any of the configuration changes i’d done to the system.
I guess the big question is “What exactly” is the proper way to restore this backup of the game i took before I moved it to the other system? Would hate to have to go through all the config again and then have the players start over.
Thanks Greatly.
