Product Name/Version: AMP Release “Triton” v2.3.2, built 31/01/2022
I have a server running 3 instances and these start by themselves, but the servers they are hosting does not. I’ve looke several times in the instance settings and there doesnt seem to be a GUI way of having the server auto start, once the instance have started.
Thank you for replying, I’m experiencing that only one of my 3 servers starts even though the setting is activated on all 3 of them. Is this a known issue?.
Seems like it updates and then really doesn’t do anything after that.
I just tried to set the Startup Mode to Start the application, which works fine, the server is started when the instance starts, but when i switch it back to Update and then start the application, it just runs the update rutine and then stops:
[11:03:22] [Core Warning] : Current time zone is set to Romance Standard Time - Servers should ideally be UTC to avoid time-zone related issues
[11:03:22] [Program Info] : OS: Windows / x86_64
[11:03:22] [Program Info] : CPU: AMD Ryzen 5 2600 Six-Core Processor (6C/12T)
[11:03:22] [Program Info] : AMP Instance ID: 794fb905-039e-44ab-ae76-6869b266cacd
[11:03:22] [Core Info] : Loaded GenericModule version 1.0.0.0 by CubeCoders Limited
[11:03:22] [Core Info] : Metrics publishing is enabled at udp://localhost:12820.
[11:03:22] [ModuleLoader Info] : Loaded FileManagerPlugin version 1.0.0.0 by CubeCoders Limited
[11:03:22] [ModuleLoader Info] : Loaded EmailSenderPlugin version 1.0.0.0 by CubeCoders Limited
[11:03:22] [ModuleLoader Info] : Loaded WebRequestPlugin version 1.0.0.0 by CubeCoders Limited
[11:03:22] [ModuleLoader Info] : Loaded LocalFileBackupPlugin version 1.0.0.0 by CubeCoders Limited
[11:03:22] [ModuleLoader Info] : Loaded CommonCorePlugin version 1.0.0.0 by CubeCoders Limited
[11:03:22] [Core Info] : GenericModule requests dependency steamcmdplugin…
[11:03:22] [ModuleLoader Info] : Loaded steamcmdplugin version 1.0.0.0 by CubeCoders Limited
[11:03:22] [Core Info] : GenericModule requests dependency RCONPlugin…
[11:03:22] [ModuleLoader Info] : Loaded RCONPlugin version 1.0.0.1 by CubeCoders Limited
[11:03:23] [Core Info] : Licence Present: AMP Professional Edition (Licenced to x)
[11:03:23] [ModuleLoader Notice] : Using keypair with fingerprint x
[11:03:23] [ModuleLoader Info] : SFTP Server started on 0.0.0.0:2224
[11:03:23] [WebServer Info] : Websockets are enabled.
[11:03:23] [Core Info] : Webserver started on http://127.0.0.1:8081
[11:03:23] [WebServer Warning] : RouterTimer@10Hz with 2 jobs started
[11:03:23] [System Info] : Checking for AMP updates…
[11:03:23] [System Info] : AMP is up-to-date.
CPID: 7500
Redirecting stderr to ‘D:\AMPDatastore\Instances\GoNServer1\Valheim\logs\stderr.txt’
Steam Console Client (c) Valve Corporation - version 1642451655
– type ‘quit’ to exit –
Loading Steam API…OK
Waiting for client config…OK
Waiting for user info…OK
Update state (0x5) verifying install, progress: 0.00 (0 / 1162785898)
Update state (0x5) verifying install, progress: 16.89 (196449002 / 1162785898)
Update state (0x5) verifying install, progress: 34.14 (396936237 / 1162785898)
Update state (0x5) verifying install, progress: 50.98 (592745089 / 1162785898)
Update state (0x5) verifying install, progress: 66.30 (770947041 / 1162785898)
Update state (0x5) verifying install, progress: 81.86 (951827649 / 1162785898)
Update state (0x5) verifying install, progress: 97.19 (1130139329 / 1162785898)
Success! App ‘896660’ fully installed.
[11:03:38] [Core:Anonymous Activity] : Authentication attempt for user amp from 127.0.0.1
[11:03:41] [Core:Anonymous Activity] : Authentication success
Thx, it seems my CS:GO servers are not affected only my Valheim server.
As shown here it works fine if i skip the update step:
[11:25:41] [Core Warning] : Current time zone is set to Romance Standard Time - Servers should ideally be UTC to avoid time-zone related issues
[11:25:41] [Program Info] : OS: Windows / x86_64
[11:25:41] [Program Info] : CPU: AMD Ryzen 5 2600 Six-Core Processor (6C/12T)
[11:25:41] [Program Info] : AMP Instance ID: 794fb905-039e-44ab-ae76-6869b266cacd
[11:25:41] [Core Info] : Loaded GenericModule version 1.0.0.0 by CubeCoders Limited
[11:25:41] [Core Info] : Metrics publishing is enabled at udp://localhost:12820.
[11:25:42] [ModuleLoader Info] : Loaded FileManagerPlugin version 1.0.0.0 by CubeCoders Limited
[11:25:42] [ModuleLoader Info] : Loaded EmailSenderPlugin version 1.0.0.0 by CubeCoders Limited
[11:25:42] [ModuleLoader Info] : Loaded WebRequestPlugin version 1.0.0.0 by CubeCoders Limited
[11:25:42] [ModuleLoader Info] : Loaded LocalFileBackupPlugin version 1.0.0.0 by CubeCoders Limited
[11:25:42] [ModuleLoader Info] : Loaded CommonCorePlugin version 1.0.0.0 by CubeCoders Limited
[11:25:42] [Core Info] : GenericModule requests dependency steamcmdplugin…
[11:25:42] [ModuleLoader Info] : Loaded steamcmdplugin version 1.0.0.0 by CubeCoders Limited
[11:25:42] [Core Info] : GenericModule requests dependency RCONPlugin…
[11:25:42] [ModuleLoader Info] : Loaded RCONPlugin version 1.0.0.1 by CubeCoders Limited
[11:25:42] [Core Info] : Licence Present: AMP Professional Edition (Licenced to x)
[11:25:42] [ModuleLoader Notice] : Using keypair with fingerprint x
[11:25:42] [ModuleLoader Info] : SFTP Server started on 0.0.0.0:2224
[11:25:42] [WebServer Info] : Websockets are enabled.
[11:25:42] [Core Info] : Webserver started on http://127.0.0.1:8081
[11:25:42] [WebServer Warning] : RouterTimer@10Hz with 2 jobs started
[11:25:42] [System Info] : Checking for AMP updates…
[11:25:42] [System Info] : AMP is up-to-date.
Mono path[0] = ‘D:/AMPDatastore/Instances/GoNServer1/Valheim/896660/valheim_server_Data/Managed’
Mono config path = ‘D:/AMPDatastore/Instances/GoNServer1/Valheim/896660/MonoBleedingEdge/etc’
Initialize engine version: 2019.4.31f1 (bd5abf232a62)
[Subsystems] Discovering subsystems at path D:/AMPDatastore/Instances/GoNServer1/Valheim/896660/valheim_server_Data/UnitySubsystems
Forcing GfxDevice: Null
GfxDevice: creating device client; threaded=0
NullGfxDevice:
Version: NULL 1.0 [1.0]
Renderer: Null Device
Vendor: Unity Technologies
FMOD failed to get number of drivers … : "Error initializing output device. " (60)
FMOD initialized on nosound output
Begin MonoManager ReloadAssembly
Completed reload, in 0.119 seconds
Microsoft Media Foundation video decoding to texture disabled: graphics device is Null, only Direct3D 11 and Direct3D 12 (only on desktop) are supported for hardware-accelerated video decoding.
UnloadTime: 0.645300 ms
Starting to load scene:start
Couldn’t create a Convex Mesh from source mesh “default” within the maximum polygons limit (256). The partial hull will be used. Consider simplifying your mesh.
[11:25:45] [Core:Anonymous Activity] : Authentication attempt for user amp from 127.0.0.1
[11:25:47] [Core:Anonymous Activity] : Authentication success
HDR Render Texture not supported, disabling HDR on reflection probe.
Unloading 6 Unused Serialized files (Serialized files now loaded: 0)
UnloadTime: 6.517500 ms
Only custom filters can be played. Please add a custom filter or an audioclip to the audiosource (Amb_MainMenu).
Get create world FrostCaves
Using environment steamid 892970
Using steam APPID:892970
Server ID 90071992547409920
Authentication:k_ESteamNetworkingAvailability_Waiting
Steam game server initialized
Using default prefs
Valheim version:0.207.20
Render threading mode:SingleThreaded
Missing audio clip in music respawn
Builder started
Loaded localization CSV:localization language:English
Loaded localization CSV:localization_extra language:English
[11:25:53] [System Info] : Application started in 11 seconds.
Game server connected
UI Group status changed Menu = True
Unloading 17 unused Assets to reduce memory usage. Loaded Objects now: 104159.
Total: 67.805400 ms (FindLiveObjects: 4.126700 ms CreateObjectMapping: 7.338000 ms MarkObjects: 55.745800 ms DeleteObjects: 0.594400 ms)
UnloadTime: 7.523600 ms
Using default prefs
Zonesystem Awake 5
DungeonDB Awake 5
Registering lobby
Audioman already exist, destroying self
Unloading 524 unused Assets to reduce memory usage. Loaded Objects now: 104835.
Total: 68.828700 ms (FindLiveObjects: 4.058400 ms CreateObjectMapping: 7.257400 ms MarkObjects: 56.409200 ms DeleteObjects: 1.103400 ms)
Zonesystem Start 5
Added 3 locations, 0 vegetations, 0 environments, 0 biome env-setups from locations_cp1
Added 1 locations, 0 vegetations, 1 environments, 0 biome env-setups from locations_mountaincaves
DungeonDB Start 5
Load world FrostCaves
Loading 152573 zdos , my id -418754993 data version:28
Loaded 100000 dead zdos
Removed 0 OLD generated ZDOS
Loaded 7507 locations
