Authentication System Failure (code 100)
OS Name/Version:
Product Name/Version:
Both are on Advanced
Controller: v2.6.0.12 | Debian Linux / aarch64 (Raspberry Pi 4)
Target: v2.6.0.12 | Debian Linux (Desktop)
I already posted a similar version of this issue in another Tech support post, but because I can’t edit it anymore and there were a couple of changes and no one responded anyway, here is the updated version:
I want to connect the Target to the controller. As far as I know, I have to connect to the web interface of the Target for that. When trying to log in, I get the following error in the Web interface:
Reason: The auth server at http://192.168.2.1:8080/ is configured not to allow other instances to authenticate through it.
ADS01 of the Target is showing:
[13:35:34] [System Activity/9]    : Authentication attempt for user joelsimon08 from 192.168.2.1
[13:35:34] [System Activity/10]   : Authentication failure for user joelsimon08 from 192.168.2.1 - PassthruDisabled
While the ADS of the controller isn’t even showing a request or anything similar.
I already asked the discord support if anyone has an idea and Mike told me it could be a network issue, which is very possible. I can’t find any issue tho.
I use a special setup: The Controller (the Raspberry Pi) is directly connected to my home router, while the Target (gameserver) is connected to the Raspberry Pi via a USB 2.0 - Ethernet Adapter. I use this setup for something that isn’t very important right now, but I’d like to keep it that way if possible.
Maybe it’s also useful to mention that for the Raspberry Pi, eth0 is connected to the router while eth1 is connected to the Target. For the Target, it’s eno1 that is connected to the controller.
Target rules:
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:2223 /* AMP:ADS01:FileManagerPlugin.SFTP.SFTPPortNumber */
ACCEPT     udp  --  anywhere             anywhere             udp dpt:12820 /* AMP:ADS01:ADSModule.Network.MetricsServerPort */
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:2225 /* AMP:ServerRafael01:FileManagerPlugin.SFTP.SFTPPortNumber */
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:2226 /* AMP:BB601:FileManagerPlugin.SFTP.SFTPPortNumber */
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:2227 /* AMP:Marc01:FileManagerPlugin.SFTP.SFTPPortNumber */
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:2224 /* AMP:Minecraft01:FileManagerPlugin.SFTP.SFTPPortNumber */
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:http-alt /* AMP:ADS01:Core.Webserver.Port */
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:8082 /* AMP:ServerRafael01:Core.Webserver.Port */
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:8083 /* AMP:BB601:Core.Webserver.Port */
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:8084 /* AMP:Marc01:Core.Webserver.Port */
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:tproxy /* AMP:Minecraft01:Core.Webserver.Port */
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:25565 /* AMP:ServerRafael01:MinecraftModule.Minecraft.PortNumber */
ACCEPT     udp  --  anywhere             anywhere             udp dpt:25565 /* AMP:ServerRafael01:MinecraftModule.Minecraft.PortNumber */
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:25566 /* AMP:BB601:MinecraftModule.Minecraft.PortNumber */
ACCEPT     udp  --  anywhere             anywhere             udp dpt:25566 /* AMP:BB601:MinecraftModule.Minecraft.PortNumber */
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:25569 /* AMP:Marc01:MinecraftModule.Minecraft.PortNumber */
ACCEPT     udp  --  anywhere             anywhere             udp dpt:25569 /* AMP:Marc01:MinecraftModule.Minecraft.PortNumber */
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:25568 /* AMP:Minecraft01:MinecraftModule.Minecraft.PortNumber */
ACCEPT     udp  --  anywhere             anywhere             udp dpt:25568 /* AMP:Minecraft01:MinecraftModule.Minecraft.PortNumber */
ACCEPT     udp  --  anywhere             anywhere             udp dpt:8080
Chain FORWARD (policy DROP)
DOCKER-USER  all  --  anywhere             anywhere
ACCEPT     all  --  anywhere             anywhere             match-set docker-ext-bridges-v4 dst ctstate RELATED,ESTABLISHED
DOCKER-ISOLATION-STAGE-1  all  --  anywhere             anywhere
DOCKER     all  --  anywhere             anywhere             match-set docker-ext-bridges-v4 dst
Chain OUTPUT (policy ACCEPT)
Chain DOCKER (1 references)
DROP       all  --  anywhere             anywhere
Chain DOCKER-ISOLATION-STAGE-1 (1 references)
DOCKER-ISOLATION-STAGE-2  all  --  anywhere             anywhere
Chain DOCKER-ISOLATION-STAGE-2 (1 references)
Chain DOCKER-USER (1 references)
RETURN     all  --  anywhere             anywhere
While the Controller rules are:
I really don’t know how to continue and would like to get it run again xD
That is a really good question. I don’t even know how this happened. Everything started to break one after another (the whole setup worked great for a time long)
  • Completely reinstalled the ampinstmgr for the pi
  • only re-running the setup
Hopefully someone is able to help :confused:
EDIT:
Something just crossed my mind; When reinstalling amp on the PI, i logically had to make a new User. I used exactly the same name with also the same password. The controller still has the “original” user from the “old” controller with the same name / password. Could this be an issue?
