Problem Description: Amp controller is unable to auth for only one target server.
Step 1 - install amp as a controller
Step 2 - install amp as a target
Step 3 - link to controller
Step 4 - convert standalone instance to target (2)
Step 5 - Link
Actions taken to resolve so far: Reinstall AMP for controller, re set up target #2. Re auth through CLI.
I cannot access inside the instances, but i can get to a page showing a different looking login screen with my branding on it. Whenever login is tried the text " Authentication System
Failure (code 100)
Reason: The auth server at http://localhost:8080/ is configured not to allow other instances to authenticate through it."
I can access instances on another target just fine.
I was looking through what amp was telling me and noticed it was attempting to auth with localhost, and that would make sense if the instance was running on the controller. However it is run on the target. I tried turning on AuthPassthrough on the target to see what happened and it stopped throwing that error, though my login still did not work.
I manually went into the config file for the instance I was attempting to log into in the first place, and low and behold the auth url was still localhost:8080. I changed it to my controller and now it works like advertised.
I dont know if this is my bad use of the CLI or if AMP needs to have this fixed but it works
TL:DR Edit the config file and change is auth server to the controller
