OS Name/Version: Windows 11 Pro
Product Name/Version: v2.4.1.2
Problem Description: Instance not working through AMP. Double checked port forwarding. When running instance, ports for Assetto Corsa aren’t active/passing traffic. When running .bat for server in the instance folder, everything works like expected and ports see traffic.
Steps to Reproduce:
Create instance for Assetto Corsa.
Launch instance.
Manage instance and Update so it downloads files from Steam.
Configure server config file in instance folder for Assetto Corsa.
Double checked port forwarding on router.
Checked with Windows firewall enabled/disabled.
Made sure instances were up to date.
Double checked ports in config file.
Changed ports in AMP for instances.
Run .bat from instance folder to make sure config was working.
