Certainly! Here’s a corrected version of your text in English:
INFORMATION:
- OS Name/Version: Debian 11 x64 (Up to Date)
- Product Name/Version: AMP - 2.4.8 - 20240129.1 / ACC - 2.4.8 - 20240129.1
Assetto Corsa Competizione crashes every time we start it. The issue seems to stem from the setting files generated by the UI panel. I have tested this on Docker with Wine, and everything works perfectly using my personal file configuration from a Windows server. Additionally, there are missing maps.
Steps to Reproduce:
- Create an ACC instance with Docker (using either the Wine or Wine8 image).
- Start the server with the default configuration.
- Wait for a response from the lobby server.
- The game crashes instantly.
Question:
I will upload corrected metaconfig.json and configmanifest.json files if I can debug the issue.
Thank you very much.
===============EDIT===============
If I bypass the GUI configuration panel by removing all cfg file in the metaconfig.json and I upload my configuration files, all is working with AMP.
