ASKA clean install fails to start
OS Name/Version: Ubuntu 24.04
Product Name/Version: AMP 2.6.4.2, Phobos
Clean AMP + fresh installation of ASKA fails.
  • Game port (7779) remains not listening
  • connection link does not work, error: “Unable to connect to serer, app id specified by server is invalid” (Steam Error in connection window)
  • Instance indicates it’s running
  • Install AMP
  • Add ASKA instance with docker containerisation
  • Install / Update
  • Start → Can’t connect
  • remove / reinstall instance
  • verified GSLT
  • verified 7779 is not in use on host system
Console
09:45:37
Input System module state changed to: Initialized.
[PhysX] Initialized MultithreadedTaskDispatcher with 16 workers.
Initialize engine version: 2022.3.62f2 (7670c08855a9)
[Subsystems] Discovering subsystems at path Z:/AMP/aska/3246670/AskaServer_Data/UnitySubsystems
Forcing GfxDevice: Null
GfxDevice: creating device client; threaded=0; jobified=0
NullGfxDevice:
    Version:  NULL 1.0 [1.0]
    Renderer: Null Device
    Vendor:   Unity Technologies
There is no texture data available to upload.
Microsoft Media Foundation video decoding to texture disabled: graphics device is Null, only Direct3D 11 and Direct3D 12 (only on desktop) are supported for hardware-accelerated video decoding.
Couldn't create a Convex Mesh from source mesh "ruins_stone_jotun_pillar_LOD2" within the maximum polygons limit (256). The partial hull will be used. Consider simplifying your mesh.
Couldn't create a Convex Mesh from source mesh "wood_jotun_statue_destroyed" within the maximum polygons limit (256). The partial hull will be used. Consider simplifying your mesh.
Couldn't create a Convex Mesh from source mesh "statue_female_head1" within the maximum polygons limit (256). The partial hull will be used. Consider simplifying your mesh.
Couldn't create a Convex Mesh from source mesh "statue_female_head2" within the maximum polygons limit (256). The partial hull will be used. Consider simplifying your mesh.
Couldn't create a Convex Mesh from source mesh "core_broken" within the maximum polygons limit (256). The partial hull will be used. Consider simplifying your mesh.
Couldn't create a Convex Mesh from source mesh "rock_ravendrake_LOD2" within the maximum polygons limit (256). The partial hull will be used. Consider simplifying your mesh.
Couldn't create a Convex Mesh from source mesh "statue_female_head3" within the maximum polygons limit (256). The partial hull will be used. Consider simplifying your mesh.
Couldn't create a Convex Mesh from source mesh "runestoneEarth_complete_2_0_C" within the maximum polygons limit (256). The partial hull will be used. Consider simplifying your mesh.
Couldn't create a Convex Mesh from source mesh "stone_jotun_foundation" within the maximum polygons limit (256). The partial hull will be used. Consider simplifying your mesh.
09:45:39
The referenced script (Unknown) on this Behaviour is missing!
09:45:40
The referenced script on this Behaviour (Game Object 'CinemachineCamera') is missing!
09:45:41
UnloadTime: 1.206000 ms
Couldn't create a Convex Mesh from source mesh "statue2_part_2_0_statues" within the maximum polygons limit (256). The partial hull will be used. Consider simplifying your mesh.
The method `Void BurstAreaOfInterestInsertAndResovleDelegate(AreaOfInterest*, Fusion.Accuracy*, Fusion.Allocator*, Fusion.NetworkObjectRefMapPtr*)` must have `MonoPInvokeCallback` attribute to be compatible with IL2CPP!
Activating game state: GameState_Boot
[STEAM] Not logged into Steam: using offline achievements (per game session).
Running game version: 1.25.1812251350._PC_Server.Release
Setting breakpad minidump AppID = 1898300
Openning connection...
09:45:42
Connected to Steam successfully
09:45:45
The session is now open!
Unloading 5 Unused Serialized files (Serialized files now loaded: 0)
UnloadTime: 1.363500 ms
Unloading 5 unused Assets to reduce memory usage. Loaded Objects now: 202464.
Total: 80.972100 ms (FindLiveObjects: 8.443400 ms CreateObjectMapping: 18.106000 ms MarkObjects: 53.961300 ms  DeleteObjects: 0.460700 ms)
Received your UserID from server. Updating local value to: YjMwYTZmOTUtNTBhYS00ZWU2LWE5NDgt
Connected to chat!
Also, from connection log 7779.txt
[2026-01-05 09:45:42] [Logging On, 4, 3] [G:1:0] Using GSLT
[2026-01-05 09:45:42] [Logging On, 4, 3] [G:1:0] RecvMsgClientLogOnResponse() : [G:1:15705895] ‘OK’
[2026-01-05 09:45:42] [Logged On, 4, 3] [G:1:15705895] RecvMsgClientLogOnResponse() : processing complete
Thoughts
Sorry to be a pain this early in the year. Having looked at other ASKA related tickets, I’ve seen that this piece of software is not the most tame / well designed.
Unluckily for you guys, that’s how I’ve learned of AMP - someone was recommending AMP for ASKA! Really wasn’t keen on doing the whole wine thing myself. Hehe. So proof of pudding right here.
ASKA is the first server I wanted to run, so it hurts quite a bit - I’ve tried and installed another game server, and that one worked immediately out of the box, so it’s definitely not an AMP installation / core issue.
I’d really appreciate any help you can offer.
Sounds to me either the install / start script is missing something, maybe the ASKA devs borked something up. It really doesn’t help that the ASKA logs are so vague. They also seemingly yoinked the “official” google drive based server setup guide, so that’s helpful. Maybe they have changed something up…?
PS, I submitted this ticket originally via AMP, and it went to the void.
Perhaps handle discourse rejected topic creations in AMP & force the user to login to discourse before starting to write the ticket in AMP.
Ta!
Gabe,
Brand new owner of an AMP licence
Hello there, I have the exact same problem with ASKA but in windows, i have like 6 servers running smoothly. Just installed today ASKA and port 7780 remains to not listening. tried all the possible combinations and i know it is something in AMP because all my other servers from steam are running great.
Thanx in advance.
Pino
ASKA uses steam networking, so doesn’t open a socket on the game port
There are heaps of guides online as to how to join an ASKA server - in-game, Mulitplayer, Join, select right server region, find server in list, connect
If home hosting, you will need port forwarding and NAT hairpin enabled
@Greelan, please bare in mind that we’re both following instructions provided by AMP, and we were receiving an error message.
Havings spent a bit more time on this today, the issue entirely lies on both ASKA’s server browser being hilariously bad, and it not getting updates frequently enough.
Yes the built in AMP connect link is broken and will not work. In a way the problem is that we’re getting mixed information - I’d reckon AMP should recognise that it can’t generate connection links for ASKA.
At the end booting the server, waiting nearly 15 minutes, and then browsing manually through 45 pages of servers in the ASKA client resulted in me finding the server, and I can confirm it’s working as intended.
I’m going to now go over to the ASKA forums because this is definitely the worst experience I’ve ever had in joining a server.
You’re right, the link is misleading, I have removed it from the template
