Product Name/Version: Halimede
Just got this program so not sure how it behaves.
Just created instance of Arma3, status says its running, don’t see any errors in console. It seems it is not downloading the program.
If you’re sharing console output, logs, or commands you have run, please make sure to use code tags
provides syntax highlighting.
* Step 1 fresh install of AMP
* Step 2 Create an instance of Arma3
* Step 3 checked for any network activity and it showing idle, not much data moved
Actions taken to resolve so far: Deleted instance and recreated it, no change
Ok, the instance was stopped and was updated and restarted, but no change in data downloading. In the manage section, it does have “Application State: Installing components” showing but that has been there for hours. Firewall has been disabled. Appreciate the response
Yes, this has been done a few times. I’m going to have to get off for a while but certainly appreciate your help and time. Also was thinking if this is a steam issue? I’ve never been asked about creds for steam. Thanks again
