Arma Reforger & Battle Eye
Hey, so I’ve seen the questions and answers here about battle eye and Arma 3. However, I do want to pose the question, is it needed for Arma Reforger as well when using AMP? I saw there is a button to disable, enable it in the Reforger menu, but not in the Arma 3 menu, so my assumption is it doesn’t matter for Reforger, which is why the button exists at all, but I did want to double check as my MILSIM is migrating over.
AMP now uses AR’s own RCON solution, which is independent of the separate BE server (though based on the same protocol)
So you can disable BE without affecting AMP connecting to RCON
