ARMA 3 wont start
OS Name/Version: Windows Server 2019/1809
Product Name/Version: 2.2.6.6
Problem Description: ARMA 3 server wont start
"This task could not be completed: Starting Arma 3… – State: 3.
Application failed to start 5 times consecutively.
Application stopped unexpectedly with error code -1073741515.
provides syntax highlighting.
  • Step 1 - reinstalled AMP
  • Step 2 - double checked steam login details (removed authentication fully)
  • Step 3 -
You’re using a very outdated version of AMP, please update to the latest version.
The error code would indicate that you’re missing a C++ runtime. Did you follow the guide and install the required runtimes? - Arma 3 on windows Guide
Lmao, link to the wrong guide
